by Muad_dib77 » Thu Jun 12, 2008 10:55 pm
Sounds like it could do with a general service.
Plugs, Filters, Fluids.
Also
Check Battery Terminals for corrosion & splits - I had to replace mine as one kept unfastening itself for some reason..
Check your Ground Cable from the starter engine also - if this is loose the car wont start.
and last but definately not least - there is no harm in cleaning your stepper motor. If this is dirty it's likely to cause the car to cut out during idling or gear changing.
These things may or may not solve the issue - but atleast once you have this done you'll know what's not causing it!
<->FTO-Ireland Shop
