rev counter
rev counter
Postby ftomad » Sat Mar 08, 2008 2:46 pm
Hi guys
I was driving along last night and my rev counter was dropping to zero when i was cruising along in 4th, i drive a 5 speed auto
Would this be just a case of loose connections? or bigger problems
ftomad
Re: rev counter
Postby ftomad » Sun Mar 09, 2008 11:32 am
ftomad wrote:Hi guys
happening in 3rd now aswel
ftomad
Postby Sebastian » Sun Mar 09, 2008 12:38 pm
do you have a delimiter/converter cip fited?
Postby ftomad » Sun Mar 09, 2008 1:29 pm
Sebastian wrote:do you have a delimiter/converter cip fited?
ive an apexi rev counter - air flow controller fitted
i dont use it but its connected
ftomad
Postby ftomad » Thu Mar 13, 2008 4:39 pm
would this be due to the fact my haft shaft is goosed?
Should i stop driving because im afraid it will cause problems later down the line?
ftomad
Postby steelroe » Thu Mar 13, 2008 7:13 pm
If the shaft is bent you are going to damage the box if you keep driving it. You are putting strain on bearings and oil seals. Get it done ASAP
