Will these wheels fit?
Postby DOS-FTO » Fri Nov 30, 2012 7:34 pm
Hi lads just a few questions to ask about wheels,
Im thinking of buying a set of alloys which are 18 inch (215/40/18). Just wondering should these fit the car ok or would they be too big? They are 5x114. Would i be able get full lock with out them hitting or scratching or anything?
Heres a link to them
http://www.gumtree.ie/cp-car-parts-acce ... -426700018
Wake Me Up When Your Vtec Kicks In
DOS-FTO
Re: Will these wheels fit?
Postby Myfeckin FTO » Wed Dec 05, 2012 12:58 pm
They don't state the width of the wheel on the Ad - the 215 tyre looks very stretched so I would say its at least an 8 or 8.5 inch width rim which will be tight on an FTO.
They also don't state the offset - this will determine how the wheel sits in the arch and will be a major factor in terms of where or if it will rub (on wheel arch or liner).
They also don't state the wheel bore - your FTO requires 67.1 but its likely you will be able to get spiggot rings to fit (these are cheap).
So maybe ask the seller to take a look at the inside rim for dimensions on offset and rim width as well as wheel bore if possible.
Users browsing this forum: Google Adsense [Bot] and 5 guests
