WTD: Lambda sensor
WTD: Lambda sensor
Postby fatboyfat7 » Mon Jun 15, 2009 2:04 pm
My 'universal' one clearly isnt up to scratch so im looking for a OE one that will pass an NCT. Pricey enough new so want to avoid that if possible...
Fully functional White GPvR....
fatboyfat7
Re: WTD: Lambda sensor
Postby Kace » Mon Jun 15, 2009 6:15 pm
Not sure this is your fault then - I replaced my Lambda with a Universal from eBay and she sailed through NCT afterwards.
Not sure OEM is going to do any better for you - next port of call for you should be CAT and/or Engine Coolant Temp sensor methinks.
Postby fatboyfat7 » Tue Jun 16, 2009 1:27 pm
Still failed on the lambda as well though... The mechanic suggested I buy I mitsi one. I just took his word for it. Porbably start with the cat if that want ye guys think.
fatboyfat7
Postby Kace » Tue Jun 16, 2009 1:44 pm
As long as you connected up the new Universal Lambda correctly it should work fine - has done for me and several other FTO owners. I don' think that the OEM version will make any difference - and you will only be buying another second hand one as new ones are about €300 :shock:
You need to install someone else's CAT and then bring it back to mechanic for emission retest.
Postby fatboyfat7 » Tue Jun 16, 2009 3:57 pm
This is kinda turning into a split conversation between here and the topic in the Technical section so I posted a response over there. Thanks for the advice Kace too. Hopefully I'll get outa this the cheapist way possible!
fatboyfat7
Return to For Sale
