gearbox problem
gearbox problem
Postby 3fto » Fri Jul 09, 2010 7:48 pm
please help, my car is a facelift gx triptronic and when you put it in reverse it clunks and when you put it in drive it drives but does not move up through the gears any advise would be gratefully received. thank you. james.
3fto
Re: gearbox problem
Postby Bernard » Fri Jul 09, 2010 7:59 pm
You're not having much luck with FTO gearboxes are you?
http://www.fto-ireland.com/forum/viewtopic.php?f=2&t=11817
Re: gearbox problem
Postby Aido C » Sat Jul 10, 2010 11:56 am
When you drive it in tip mode will it go up through the gears?
Aido C
Have you seen my FTO tattoo?
Re: gearbox problem
Postby 3fto » Sat Jul 10, 2010 8:13 pm
it does nothing in tiptronic mode
3fto
Re: gearbox problem
Postby Aido C » Sat Jul 10, 2010 8:26 pm
3rd gear is the default gear for the automatic transmission so is it just driving in 3rd the whole time? Did you check all the fuses, the ones in the drivers foot well?
Aido C
Re: gearbox problem
Postby 3fto » Sun Jul 11, 2010 7:59 pm
Aido C you are a god, thanks for your advice my problem is now sorted, thanks for your help i really appreciate it. :D
3fto
Re: gearbox problem
Postby Aido C » Tue Jul 13, 2010 10:17 pm
No worries :smt002
Aido C
Re: gearbox problem
Postby gmaster » Sun Jul 18, 2010 9:11 pm
Having some issues too with my tip box, where's this fuse you speak off cant do any harm to check it, thanks. Which fuse would it be?
gmaster
Re: gearbox problem
Postby 3fto » Sun Jul 25, 2010 5:37 pm
I checked all my fuses as there were some more to replace but I think the gearbox fuse is across the top row, it was a 10 amp fuse. hope this helps you out.
3fto
