help needed asap
help needed asap
Postby martin25 » Wed Feb 11, 2009 7:58 pm
hi guys,i have just joined this fourm as i now have a fto mivec i purchased 2 days ago,i have a problem at the moment,it is due for an mot friday,and the speedo or rev counter is not working at all its in mph 180mph it says,the petrol and temp are fine?any help would be great thanks martin.
could i test it or anything?
martin25
Postby Dragonheart » Wed Feb 11, 2009 8:31 pm
You might have to replace the dials or else it could just be a loose connection at the back of the dials? Have you taken them out and had a look?
Postby martin25 » Wed Feb 11, 2009 8:35 pm
thanks for the quick reply,no i havent took them off yet!!but i will try tomorrow,is there any way of telling if it is broke or burnt out?will this fail the mot on the speedo?
martin25
Postby Dragonheart » Wed Feb 11, 2009 8:42 pm
I'd imagine it would fail on that, though they hopefully wont be driving the car into the centre from the car park at enough to register on the speedo. Could be the limiter that is broken, if its in mph shes been converted and prob delimited at the same time. You can buy a new limiter from camskill. I'd check the connections first though to be sure.
Postby martin25 » Wed Feb 11, 2009 8:48 pm
ok mate thanks,how can i tell the limiter thing ect,as i havent got a clue,thanks martin
martin25
Postby Dragonheart » Wed Feb 11, 2009 9:02 pm
Postby kevinod » Wed Feb 11, 2009 9:03 pm
I was told that the speedometer doesn't need to work for the MOT. Never did an MOT though so can't vouch for that.
As DH said, if the dial is MPH it's likely there's a convertor in there. It's Km/h from the factory. I'd reckon that would be more likely to fail than your dials.
That said, get the speedo out (easy job, it's only a few screws) and check the contacts at the back of the unit to make sure they're clean.
Postby martin25 » Wed Feb 11, 2009 9:12 pm
ok thanks guys,i will try cleaning the connectors on back of speedo,and i will get back to you tomoz,thanks
martin25
Postby Myfeckin FTO » Thu Feb 12, 2009 2:03 pm
Are they the original or aftermarket dials?
Postby martin25 » Fri Feb 13, 2009 11:02 pm
hi guys,i said i will get back after i cleaned the connecters on the speedo and rev,i did that and still nothing has changed,everything works eccept for the speed and rev counter,any more ideas i could do thanks?
and today i took it for its mot,and the speedo started workin then stopped again.
martin25
Postby CJ » Sat Feb 14, 2009 10:06 am
As per MfFTO, if theres aftermarket dials in place, improper fitting can screw up the readings.
My guess is that a dodgy KPH - MPH convertor is causing the problem.
Postby martin25 » Sun Feb 15, 2009 4:00 pm
hi again ,i ive took a few pics of my speedo,i kno you said about the converter limter thing but i cant see it any where, all i can see is 2 conections,how can i test if the ifs is bust thanks?and where would that be...
http://img8.imageshack.us/my.php?image= ... 093qc3.jpg
http://img15.imageshack.us/my.php?image ... 092df8.jpg
http://img21.imageshack.us/my.php?image ... 094kd3.jpg
martin25
Postby martin25 » Sun Feb 15, 2009 4:32 pm
hi i just tried this what i found on here in a fourm tested the pin located and it is reading 7volt,so would that be ok so its not the ifs
How to check if IFS is u/s.......using a multimeter....
1. Remove clock console to reveal 2 multi-pin plugs. Start
engine.
2. Looking at the left plug (C05) locate pin 18 (bottom row 5
in from left-white wire)
3. Set multimeter to read more than 5V. Put +ve probe to this
pin and -ve probe to earth. (Use bolt in centre of console
recess for convenience)
4. If multimeter does not read 5V then the problem is IFS or
wire from IFS to dial console....
martin25
Postby martin25 » Tue Feb 17, 2009 12:05 am
martin25
Postby kevinod » Tue Feb 17, 2009 5:41 pm
I've never had one, but doesn't the convertor sometimes connect in at the speed sensor itself, rather than at the dash?
