The Bull wrote:problem turned out to be low brake fluid level, might be worth a look.
johnny wrote: brake fluid could be low or ur pads may need changing
baldtyres wrote:The pads were changed last service - 10000klms ago so I wouldn't imagine it's that.
baldtyres wrote:Was working on the loose wire theory myself but if it's the fluid (see previous thread) can anyone verify its location?
baldtyres wrote: but those warning lights must be there for some purpose....possibly to warn me of something.
pergau wrote:It could be a sticky switch on the handbrake AFAIK ir's jut a microswitch that is pressed in by the handbrake lever.
baldtyres wrote:pergau wrote:It could be a sticky switch on the handbrake AFAIK ir's jut a microswitch that is pressed in by the handbrake lever.
Hope so, thats my usual diagnosis![]()
Head in the sand or black tape over dials should fix it!
gt94 wrote:Did you have a screeching noise by any chance when u drove this happened me in my gt starlet light stayed on.My handbrake cable was frozen as car had been parked up for about 6hrs on a very cold night.
steelroe wrote:I had this problem some time back and it turned out to be a stuck diagphragm in the reservoir. Remove the white cap and give the rubber a tap. Replace and see if it solves the problem
Anyone got a solution to a small Haemorrhoid problem, not sure if it's FTO related
The Bull wrote: if its not, i recommend a box of matches and a paint scraper ( or preperation H if your a wimp)
Good look with the brakes
