GX audio problem, pictures
Postby fox » Mon Mar 15, 2010 5:09 pm
Hi, I couldn't find a right thread, so I though I'll ask.
I wanted to change the stereo for a new one from the original mitsubishi stereo.
But I have a problem, the sockets doesn't match.
Here are 4 different things needs to be connected, anyone knows where to buy or have an adaptor socket or something?
The new radio is Sonichi S7000-DVD/CD Player
Thanks a million.
1997 FTO GX
fox
Re: GX audio problem, pictures
Postby CJ » Mon Mar 15, 2010 6:34 pm
In the first pic, the only connection you will use is the large antenna plug, the other smaller one is not required in Europe.
You'll need to buy an ISO harness adapter to plug the white lead into your stereo, search the for for 'ISO', Alternatively, chop off the head and wire manually (cable layout is on the forum). Its unlikely, you'll be able to use the stock CD changer (black plug) with your new stereo.
Postby fox » Mon Mar 15, 2010 6:49 pm
Double Thanks CJ :)
1997 FTO GX
fox
Postby gfalls » Tue Mar 16, 2010 6:18 am
Can't blame a bloke for trying viewtopic.php?f=4&t=11387 :D
Be nice to nerds. Chances are you'll end up working for one.
gfalls
Postby fox » Mon Mar 22, 2010 12:18 pm
Right, just got my harness delivered.
Will be mounting new stereo today.
I've noticed and read somewhere that the ground connector needs to be screwed in somewhere.
Where is the best place to screw it in?
1997 FTO GX
fox
Postby gfalls » Mon Mar 22, 2010 1:30 pm
fox wrote:Right, just got my harness delivered.
When you put the unit in, just attach the ground to one of the fixing screws that go through the brackets. That should do it.
gfalls
Postby fox » Mon Mar 22, 2010 5:01 pm
Cheers bud :)
1997 FTO GX
fox
