Pistons or Head-gaskets?
Postby RedOut » Thu Apr 16, 2009 10:43 am
Hi!
Can anyone tell me if it is possible to get pistons or head-gaskets that would give my 6A12 Mivec around 12:1 compression?
This is to be a race only engine :twisted:
Thanks,
RedOut*
RedOut
Re: Pistons or Head-gaskets?
Postby kevinod » Thu Apr 16, 2009 11:58 am
Some question for your first post! :wink:
I don't know the answer to your question, but I'm curious to know how you came to the figure of 12:1 compression?
Postby RedOut » Fri Apr 17, 2009 1:01 pm
I am not running pump gas and compression gives power. 12:1 is what I use to run on my 4AGE long pass those days :twisted:
I have extractor,2.5 tune length exhaust,piggy pack ECU, 70mm throttle body with my own intake manifold and chamber which I have not finished or tested as yet and a few other bits.
12:1 is just what I want to run :smt004
RedOut
Postby Kace » Fri Apr 17, 2009 1:58 pm
I wish I knew enough to understand what Red's on about :shock:
Where's Dan when you need him :?:
Postby d_dan » Fri Apr 17, 2009 8:24 pm
Hi and welcome to the club.
Sadly i think your going to need new pistons to get that sort of compression
as with the FTO's standard 0.3mm head gasket and standard pistons you have 10:1 compression
and your not going to have a propper gasket and get 12:1
I can get you 6 pistons,pins, locks, contact reduction grooves, pin oilers and rings €825 + Vat
These can be custom made for your compression.
With optional Carrillo rods with 5/16" CARR bolts for €282 + VAT
Would it be possable to skim the head back enough to raise the compression?
And then get a custom made head gasket made?
http://www.ferriday.co.uk (Micks the man in the know there)
d_dan
Postby RedOut » Sat Apr 18, 2009 5:54 am
Hi!
d-dan thanks alot! Can you give me the prices in US dollars with the VAT, the rods and the pistons.
Thanks again,
RedOut*
RedOut
Postby d_dan » Sat Apr 18, 2009 10:48 am
is about $1,760* USD
Thats the price that i got last time i checked anyway
d_dan
Postby RedOut » Mon Apr 20, 2009 5:52 am
OK!
That is almost $4000 of my money.I will save for those things after I'm finish with the roll-cage.
Thanks again,
RedOut*
RedOut
Postby d_dan » Mon Apr 20, 2009 1:20 pm
are you building a propper cage or buying a dash dodger?
d_dan
