Adjusting idle
Adjusting idle
Postby Kace » Thu Apr 19, 2007 9:24 am
Guys - quick one. Could someone confirm how to adjust the idle on a GPX. I installed a new stepper which is great, but my idle at 'hot' temp is now down at about 1000rpm - this used to be at about 1300 rpm and I would like to adjust it upwards.
Ta
Postby mcgon1979 » Thu Apr 19, 2007 9:28 am
idle at hot temperature should be about 750 - 900rpm... 1300rpm seems very high except for a cold engine just started etc? anyone else concur?
mcgon1979
Re: Adjusting idle
Postby Muad_dib77 » Thu Apr 19, 2007 9:42 am
Kace wrote:Guys - quick one. Could someone confirm how to adjust the idle on a GPX. I installed a new stepper which is great, but my idle at 'hot' temp is now down at about 1000rpm - this used to be at about 1300 rpm and I would like to adjust it upwards.
Ta
Seems a tad high unless maybe you have the aircon on full blast?
Postby Kace » Thu Apr 19, 2007 9:50 am
Hmm - maybe it was high all along then. I've been driving the car for 7 years now and it has always idled steadily at about 1300 (hot or cold). Aircon would probably only drop it about by about 500.
If I could change this post to a 'poll' now, I would. Let us know what your cars idle at guys.... :?:
Postby Muad_dib77 » Thu Apr 19, 2007 9:52 am
I have a feeling we'll be seeing a few different figures..
I'll check mine this evening :-)
Postby kevinod » Thu Apr 19, 2007 11:31 am
Mine is generally a little above 1000rpm for a short while when cold and goes to about 750/800 mark once its warmed up a little. 1300 sounds pretty high to me too... I'd imagine it would mention the correct approx revs in the workshop manuals... I'll take a peek maybe.
Postby Kace » Thu Apr 19, 2007 11:37 am
Actually - now that I think about the needle position, it was probably more 1200 rather than 1300, but definitely not down at 1000 or less.
Postby kevinod » Thu Apr 19, 2007 11:41 am
Found it... p.41 of the first workshop manual under Idle speed check:
Curb idle speed: 750 +/- 100 r/min
If the idle speed is outside the standard value, check the MPI components by referring to GROUP 13A - Troubleshooting.
Postby baldtyres » Thu Apr 19, 2007 11:44 am
Agreed! Normal idle is def 750+-
Midlifecrisisinagpx
baldtyres
