Alternator
Alternator
Postby Muad_dib77 » Mon Apr 23, 2007 11:35 am
Upon have a bit of a browse through eBay.. I do this a couple of times a day cause I'm that boring.. I've seen a numbe rof times that people flog Daewoo alternators as being compatible with FTOs ..
Did anybody try fitting one??!
It all seems quite unlikely to me..
Postby Myfeckin FTO » Mon Apr 23, 2007 1:52 pm
I had heard similar before - would be surprised if true to be honest.
Believe the GR has a different alternator to the GPX in any case (2pin vs 4pin).
I would go the route of getting your current alternator rebuilt over buying a new one in any case.
Postby Mustang » Mon Apr 23, 2007 2:11 pm
News to me but not totally unbelievable. When I had the cyborg, my mechanic mentioned that the same 4G92 engine (modefied and without mivec) was used in some daewoo, kia or other korean rubbish (can't remember which). On the basis that mitsi are supplying designs to Korean manufacturers this may be true. Surely the FTO alternator is used on other mitsi models?
Mustang
Postby CJ » Mon Apr 23, 2007 3:31 pm
Mustang wrote:Surely the FTO alternator is used on other mitsi models?
Not according to CAPS - FTO specific it would seem.
Any links to those ads Muad?
Postby Muad_dib77 » Wed Apr 25, 2007 9:47 am
Of course I can't find any right now - typical.
I didn't check all of the shop listings though..
http://search-desc.ebay.co.uk/search/se ... p=1&fsoo=1
Postby mark » Tue Jun 12, 2007 10:30 pm
probably off subject now but GR is 2pin and GPX is 4pin, changed mine a few years ago, you need to pop the drive shaft out to get it out. I think it has a different mounting also. I was able to get a new one as opposed to factory recon which I would recommend as it's a bit of work to get out. Somewhere way back in this forum are the details and serial numbers etc.
mark
Postby johnny » Wed Jun 13, 2007 4:15 pm
mark wrote:......you need to pop the drive shaft out to get it out. I think it has a different mounting also......
I found the easiest way was to drop the exhaust down... trickiest bit is getting at the awkward back manifold bolts....
johnny
Postby mark » Wed Jun 13, 2007 5:26 pm
Yep the manifold is a pain alright. The drive shaft option sounds quite daunting but it's not really. Some people also undo the engine mounting bolts but I think this puts a bit too much strain on them.
mark
