Good Auto-Electrcian
Postby Aido C » Wed Oct 21, 2009 8:33 pm
Can anyone recommend a good auto electrician in Dublin? Preferably north side but doesn't matter too much. I want to get the car sorted. I changed the engine coolant temperature sensor today. Thought that my be why the mivec is not working but it didn't make any difference. Think it's time for a professional again.
Aido C
Have you seen my FTO tattoo?
Re: Good Auto-Electrcian
Postby Sebastian » Wed Oct 21, 2009 8:42 pm
Aido C wrote:Can anyone recommend a good auto electrician in Dublin? Preferably north side but doesn't matter too much. I want to get the car sorted. I changed the engine coolant temperature sensor today. Thought that my be why the mivec is not working but it didn't make any difference. Think it's time for a professional again.
can you guide me how to do it .. this is my next diy job
Postby Aido C » Wed Oct 21, 2009 11:23 pm
Which? Changing the temperature sensor? Takes 2 minutes. Its on the top of the engine about 5 cm back from where you put the coolant in. It's on the side of the engine near where the bell-housing meets the engine. It has two wires going into it. Pull the plug off and unscrew the sensor with a 19mm spanner. Probably good to move the air filter pipe for visibility.
Hope this helps. If you have any questions just ask.
Aido C
Postby CJ » Thu Oct 22, 2009 9:10 am
Aido, may be a bit out of your way but I can recommend Blanch Auto Electric (018200840). The guy is good but he's always busy.
Postby Aido C » Thu Oct 22, 2009 12:59 pm
Thanks CJ.
Aido C
Postby Kace » Thu Oct 22, 2009 1:17 pm
Aido C wrote:Which? Changing the temperature sensor? Takes 2 minutes. Its on the top of the engine about 5 cm back from where you put the coolant in. It's on the side of the engine near where the bell-housing meets the engine. It has two wires going into it. Pull the plug off and unscrew the sensor with a 19mm spanner. Probably good to move the air filter pipe for visibility.
Be careful when doing this that you don't puncture the coolant hose that runs near the sensor. I did this when trying to unscrew mine. This made the job take a lot longer than 2 mins.
Kace
