by Daz » Fri Dec 07, 2007 5:22 am
hhh1234 wrote:as it says above when i go over bumps it sounds like there is a knocking cumming from the rear left. also does anyone know if when changing the suto gear box oil. is there a filter to be changed and if so were can i get one.
When changing the Auto gear box oil yes there is a filter to be changed best place to get one quickly would be camskills,
http://www.camskill.co.uk/products.php? ... 11s12p2700 but local motor factor's should be able to get you one if you take in the number to them.
As reguards the rear knocking Have you replaced your exhaust lately? could be that the replacement i's quite the perfect fit also it still could be the exhaust it might have slipped out of the rubber hanger. Would really need to hear the noise ti know better but thats something you can check quickly for starters.
Daz...
