Random LED light under centre console
Postby dcfto » Tue Aug 26, 2008 12:34 pm
Hi lads,
I pulled out my centre console to put in blue leds instead of the original bulbs and as said above there is a random wire with a bulb on the end of it. It is wired to the light that goes into the cigarette lighter, it works and all but i just dont know where its supposed to go. Its just lying there loose now, it wasnt attached to anything when i removed the plastic surround. My neighbour had a look and he reckons i should take the fascia off the gear stick surround as it might be a light for the P N R D symbols. Anyone got any idea...Just thought I'd throw it out there any how and see what ye have to say...
Cheers,
dc
dcfto
Postby colm_mcm » Tue Aug 26, 2008 12:36 pm
there should be both a light for the cig lighter and for the ashtray.
Postby dcfto » Tue Aug 26, 2008 12:42 pm
Just at the back of the the section where the ashtray slides in theres a hole alright but when I slide the ashtray in it knocks it out. Theres a (for want of a better way to say it) protruding nub type thing fixed to the back of the ashtray which fits the hole perfectly. Should I trim this 'nub' off and fix the bulb into the ashtray?
dcfto
Postby colm_mcm » Tue Aug 26, 2008 12:51 pm
no it's not the hole at the back of the ashtray.
the bulb holder for the ashtray is on the bottom right hand corner, you'll see a little window where the light shines through
Postby Muad_dib77 » Tue Aug 26, 2008 12:52 pm
I haven't had to trim the ashtray at all..
Have another fiddle with it -as far as I remember the led fitting kinda twist a half turn and is then kept in place by a nub or similar..
Postby dcfto » Tue Aug 26, 2008 2:12 pm
Cheers Colm, that did the job. it wasnt connected when i pulled the out the console surround and i couldnt find that little bracket! sorted now anyhow, stuck it in just there at lunch.
Anyone know how to fit a bulb for the ignition barrel, havent really looked at it yet but any advice/info would be appreciated.
Cheers,
dc
dcfto
Postby Sebastian » Tue Aug 26, 2008 6:23 pm
you have to strip most of the covers there .
not 100% sure but i think steering wheel has to come down.
was trying to change that bulb miself last week and it was a job bigger than i expected.so left it
Postby Muad_dib77 » Wed Aug 27, 2008 9:16 am
I replaced mine when I had everything off anyways..
As far as I remember you need to to remove the steering wheel to get the covers off but I'm not 100% sure..
Once you have the covers off though it's straightforward enough - the most important thing you need to know is..
if you have to apply more force to getting the covers off than you thought you had to - you've missed a screw..check and double check that you have all the screws out - ones up a really deep "hole" in the underside of the cover and you'll need a long screwdriver to get at it..
