dave100 wrote:Kev, the bore is the diameter in mm of the central hole in the wheel.
If it is too big for the hub spigot, then the wheel will fit, but vibrate without fitting the plastic ring.
If it is too small for the hub spigot then it needs machined by a specialist engineering shop.
Too big is defo betr than too small-as usual
Hey, you know size matters!
So when you say central hole, thats the gap that the hub fits into, right?
*edit - pic didnt' come out right*
Just trying to reconcile that though with wheel sizes... a 17" wheel is going to have a wider gap there, so a 16" and 17" wheel are going to have different bore?
