Wheel Alignment / Laser
Postby RussMan » Fri Jul 08, 2005 11:46 am
Hi,
I'm not happy with the way the front end feels on the fto.
I'm guessing it's down to the new front shocks the cowboys fitted when i bought the car.. i.e screw on .. wheel on .. see you later.
I was wondering can anyone recommend a good place for me to get this work done at a relatively low cost if possible?
Thanks
Russ
RussMan
Re: Wheel Alignment / Laser
Postby soc » Fri Jul 08, 2005 11:57 am
RussMan wrote:I was wondering can anyone recommend a good place for me to get this work done at a relatively low cost if possible?
Thanks
Russ
Dave McCann in Coolimine industrial estate (out near the blanch centre) - they have laser alignment equipement and are as good as the best you'll get in ireland. I had my old FTO and recently my Golf done there and both times the difference after was amazing!
4 wheel alignment is €65
You'll need to book the car in and will get them on 8202221
soc
Postby Myfeckin FTO » Fri Jul 08, 2005 1:19 pm
RussMan wrote:Hi,
Russ
Russ - Do you have coilovers on the back and normal dampers and springs on the front? What dampers and springs went on the front - OE spec or something else?
Postby RussMan » Fri Jul 08, 2005 1:48 pm
Cheers Shane will take a look when i get paid in a few weeks.
There was fancy cil over shocks on front which were faulty so i believe that they were replaced by OEM's but can't be sure as no faith in dealer tbh. Can you recommend somewhere else also? Near Sandyford area at all?
RussMan
Postby kevinod » Fri Jul 08, 2005 2:54 pm
shane wrote:Dave McCann in Coolimine industrial estate (out near the blanch centre) -
That seems pretty good, just read a post on ftooc.org, talking about CMS over there doing it for £94!
Kev.
Postby Myfeckin FTO » Fri Jul 08, 2005 2:54 pm
RussMan wrote:Cheers Shane will take a look when i get paid in a few weeks.
There was fancy coil over shocks on front which were faulty so i believe that they were replaced by OEM's but can't be sure as no faith in dealer tbh. Can you recommend somewhere else also? Near Sandyford area at all?
If I were you I'd ask the dealer the question what dampers (Genuine Mitsi FTO, KYB,Bilstein etc)or springs were fitted (where the springs lowered as per Tein, Eibach, Apex etc) and mention to them you have a problem - they should not have handed over a car to you with questionable handling.
I would not be too sure how an FTO would handle with low coilovers on the back and standardish dampers and springs on the front - might look a little weird as well with the back on its hunkers and a gap between the front wheels and arches.
Postby RussMan » Fri Jul 08, 2005 3:02 pm
funny you shoul mention that beacuse it does look slightly raised on the front. To be honest i really don't want to go anywhere near the dealer again.... most unprofessional.. imagine asking to use the bathroom and been told to go out the back and go between the cars.... CLASSY!!
I'll be sticking with genuine mitsu dealers or people who come recommended until i can afford the boxster and its plain sailing from there :)
RussMan
Postby soc » Fri Jul 08, 2005 3:35 pm
RussMan wrote:funny you shoul mention that beacuse it does look slightly raised on the front. To be honest i really don't want to go anywhere near the dealer again.... most unprofessional.. imagine asking to use the bathroom and been told to go out the back and go between the cars.... CLASSY!!
As MfFTO has already said it's not a good thing if you're running the car with shortened shocks at the rear and standard shocks at the front. Apart from the obvious issues of height difference and resulting imbalances the damping would be totally different. All this will have a real negative effect on the handling.
My advice is get Paul Nolan to look at the car and see what he thinks - he's a lot of experience with FTO's so should be able to give you good advice.
soc
Postby Myfeckin FTO » Fri Jul 08, 2005 3:37 pm
RussMan wrote:I'll be sticking with genuine mitsu dealers or people who come recommended until i can afford the boxster and its plain sailing from there :)
Wouldn't really bother with the Mitsi dealers either - just find a good mechanic that knows his stuff - Paul Nolan being a case in point for you guys based in Dublin.
Postby kevinod » Fri Jul 08, 2005 3:51 pm
Myfeckin FTO wrote:Wouldn't really bother with the Mitsi dealers either
Also true for parts, such as front bumpers that you can get for about half price! :wink:
Sorry, couldn't resist the plug!
Postby RussMan » Fri Jul 08, 2005 4:35 pm
Right sold i'll go to Paul Nolan... need to wait for pay day... get a full service while at it !!!
RussMan
Postby AL » Fri Jul 08, 2005 6:28 pm
sorry to hear your woes about that car, but i did warn everyone on this site about the car and the dealer you brought it off, thats why i buy direct in the first.
but your well within your rights to bring car back and demand an identical or similar replacement pair of front shocks, get them to source a replacement pair, BUT DONT LET THEM FIT THE SHOCKS :?
AL
Postby RussMan » Wed Jul 13, 2005 1:29 pm
Why was there a post about this car???? Ouch why didn't i see that!!
Car from an engines perspective is running well just the front end needs TLC.... no money for it at the moment but soon as its spoiling the effect
RussMan
Postby soc » Wed Jul 13, 2005 1:58 pm
RussMan wrote:Why was there a post about this car???? Ouch why didn't i see that!!
I wouldn't worry about it too much - it may cost you a bit to get it running sweet but it'll be worth it in the end - not many manual vR's around ;)
soc
Postby CJ » Wed Jul 13, 2005 2:32 pm
shane wrote:not many manual vR's around ;)
Agreed, if I'm not mistaken, theres no other current (Irish) GPvR owner on this forum, count yourself lucky ;)
Postby RussMan » Wed Jul 13, 2005 2:34 pm
:oops: blusing now - i feel so priv... there's very few differences really though.. isn't there... its a little lighter.. has red seats etc. and a big spoiler... anything else?
RussMan
Postby CJ » Wed Jul 13, 2005 2:42 pm
RussMan wrote:anything else?
Yeah, the imporant bits - LSD, HIDs and sports suspension!
Postby RussMan » Wed Jul 13, 2005 2:45 pm
Or not sports suspension anymore :cry:
RussMan
Postby AL » Wed Jul 13, 2005 11:39 pm
russman, i dont think those red seats go with a black car :r
they wud look better in my white fto, i suggest a straight swap, wot you reckon :wink: pleaseeeeeeeeeeeeeeeeeeeeeeeee :?
AL
Postby RussMan » Thu Jul 14, 2005 9:54 am
I'll tell you what... when i get my leathers i'll put them up for sale on this site first... guaranteed irish instead of .org. I assume you can just put these red covers onto another fto no probs?
RussMan
Postby Myfeckin FTO » Thu Jul 14, 2005 10:20 am
RussMan wrote:I'll tell you what... when i get my leathers i'll put them up for sale on this site first... guaranteed irish instead of .org. I assume you can just put these red covers onto another fto no probs?
Yip - they go on no hassle - You'll have a bit of interest in them as well.
Def worth about €50 :lol:
Postby AL » Thu Jul 14, 2005 6:57 pm
i might be able to go to 51 euro for them :shock: , but they'd only look any good in my car, seriously though........... id leave your seats well alone man, they're the biss............ive said it b4 and ill say it again, dont go near leather :roll:
AL
Postby CJ » Thu Jul 14, 2005 7:16 pm
AL wrote:ive said it b4 and ill say it again, dont go near leather :roll:
Here we go again.... :roll: ;)
Russ, don't let him put you off, getting leather installed is one of the best mods I've undertaken on an FTO, at the end of the day, its a personal choice. That said, red seat covers are rare enough, if you do consider selling them and you want to make a few quid, stick an ad on the FTOOC with a view to driving people towards an ebay auction.
