FTO Light bulb listing
FTO tips and tricks
Postby steelroe » Sun Jun 29, 2008 12:59 am
Guys I cannot find a listing anywhere of all the bulbs used on the FTO. Wanting to get some upgrade bulbs but not sure of the codes?Technical term for some of the the bulbs.
So here are the ones I know, please add in the ones I have left blank.
Full Beam --- HB3 (9005) 60W
Dip Beam --- HB4 (9006) 51/55W
Fog Light (pre Facelift) --- H3 55W
License plate ---- W5W (501 Wedge) 5W x 2
Side indicators --- W5W (501 Wedge) 5W
High level brake light --- W5W (501 Wedge) 5W x 2
Facelift Fog --- H3 55W
Front Indicator --- P21W (Parallel Pins)
Front Parks --- W5W (501 Wedge) 5W ????
Brake Light/Park ---- P21/5w (Dual element staggered pins) x 2
Interior Mirror Lights ---- 39mm Festoon
Ignition Barrel Light --- T5 Wedge Bulb
Reverse Lights ---- P21W (Parallel Pins)
Rear Indicators ---- P21W (Parallel Pins)
Postby kevinod » Sun Jun 29, 2008 1:41 am
Camskill lists the fog light as the same for all FTOs.
The parts database thingy probably lists all these?
Postby Muad_dib77 » Mon Jun 30, 2008 9:25 am
What a brilliant Idea - once the blanks are filled in we'll stick this in the Kbase!
Postby steelroe » Mon Jun 30, 2008 11:08 am
Here is the complete list as I see it, please update as you see fit.
Postby Big Dogg » Fri Oct 17, 2008 2:13 pm
Does that dipped beam headlamp bulb require any "mods" to make it fit, or will it go straight in? The only thing I could find on the net regarding this said you could use a Ford Puma bulb, but had to cut bits off to make it fit. Also, how can the bulbs be removed/replaced?
TIA
'95 2.0 GPX Auto
Big Dogg
Super unleaded
Super unleaded
Postby steelroe » Fri Oct 17, 2008 2:20 pm
If you buy the 9006 bulb it fits sraight in. You need to twist the bulb to remove it. Alos the plug connection can be very stiff to remove, You need to be forceful with it, but used a cloth or something to prevent injury should the lamp break.
Postby CJ » Fri Oct 17, 2008 2:24 pm
Big Dogg wrote:Does that dipped beam headlamp bulb require any "mods" to make it fit, or will it go straight in?
Search is your friend Dogg:
http://www.fto-ireland.com/forum/phpBB2 ... php?t=1409
Postby Big Dogg » Fri Oct 17, 2008 4:16 pm
Do I just twist the bulb anti-clockwise to remove it then? There's a metal wire that looks like some sort of clip running round the plastic. I imagined I would have to remove this before the bulb would come out :?
'95 2.0 GPX Auto
Big Dogg
Super unleaded
Super unleaded
Postby Dragonheart » Fri Oct 17, 2008 7:36 pm
I presume the clip folds back, I havent changed the bulbs on the FTO but with any other car it does, its just a retaining clip.
Postby CJ » Sat Oct 18, 2008 7:47 am
Good stuff Dogg. You coming to the Tyrone meet in Nov out of interest?
Re: FTO Light bulb listing
Postby TayStyles » Thu Dec 08, 2016 10:24 am
The Bulb inside the Tiptronic gearstick housing (lighting up the letters and numbers) is a T10 1W WEDGE with a 9mm Base.
TayStyles
Return to FTO Knowledgebase
